- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
2015 Bravia Android TV Issues
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I just did a "initial setup" again, and this time it asked a question about, Freeview, Freesat, Virgin, etc.
I picked Freesat and the channel list now seems to be in some kind of order, but it still does not populate it with a guide. So is this TV, 43W807 Freesat compatible or not? If it isn't why does it ask about a Freesat input?
Still getting some low level "hissing" sound on some movies played from the NAS, not sure if it is linked to the Clearsound + setting.
Does anyone know if the Youview update coming "Next Year" will work with the satellite input?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Wanted to add, we got a HT-CT80 soundbar with this TV, and with it positioned infront of the TV the remote for the TV doesn't work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thats because your blocking the sensor with it. I have the same setup and I just have to raise the remote slightly more.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Verzonden van mijn HTC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've got a KDL-43W755C with an HT-CT380 sound bar. When connected via HDMI ARC or Optical the audio cuts out intermittently for a second or so, this is extremely annoying and happens quite often. When I switch back to the internal TV speakers the sound is perfect. It happens with Freeview content but doesn't seem to be an issue with content I play back through Plex. Has anyone else experienced a similar issue with a sound bar attached? I thought I could live with this TV's numerous quirks but I'm getting to the end of my tether, it's ridiculous that 2 compatible Sony products purchased together in a bundle do not work together.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I had issues with a sony sound bar, CT370. What i found worked for me, was too do a full tv reset after the last patch, then set the tv up again from scratch. Since doing this i have had no more sound issues with the sound bar, (this does not inclued sound lag, as this issue has not been fixed by sony yet)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@alellio01 wrote:I had issues with a sony sound bar, CT370. What i found worked for me, was too do a full tv reset after the last patch, then set the tv up again from scratch. Since doing this i have had no more sound issues with the sound bar, (this does not inclued sound lag, as this issue has not been fixed by sony yet)
Thanks! Will give this a try tomorrow and see if it improves things.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've got the HT-CT380 soundbar as well (using ARC) and suffer the same drop in sound but it doesn't happen that often for me. But I do get lip sync issues on the sound bar all the time. It does seem worse when we are using an external source (usually our YouView box). Lip sync issues with the TV speakers seems to have gone with the latest update but using the sound bar it is definitely worse. I can't believe Sony can't fix a simple thing like this. It has got so bad the wife refuses to use the sound bar now!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I found returning to "Guide" and then going back again to the programme cleared the fault for a while.
But it WILL come back again.
I now use a Humax box for my viewing.
It has a workable EPG.
