- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD49XF7596 bluetooth sound interrupted
Hello! Tell me please, can voice search and headphones work together with bluetooth? I have when the remote control and headphones are connected in the bluetooth settings together - the sound is interrupted, when you remove the remote control from the settings - everything is fine! (Sony KD49XF7596 , Philips 3075 headphones) Thank you in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Your tv model does not support bluetooth headphones at all...how did you connect them?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you very much for your answer, I am answering your question. I downloaded the Bluetooth Scanner app on Google Play. Then, through the application, I connected the headphones. Then in the bluetooth settings I turn them on or off, I can do the same with the remote control. But the trouble is that when they are together in the settings, the sound in the headphones is intermittent. I delete the remote control everything is fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Than you should contact the developer or try another app. If I remember well bluetooth pair should be another
