- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
no sound unable to get sound on samsung soundbar connected by arc to Bravia xe9305 arc port
has anyone managed to connect thier XE93 to a samsung soundbar using ARC?
ive gt a bravia XE 9305 andam trying to connect it to a samsung HW MS650 soundbar using the ARC ports on the bravia and the soundbar but am not getting any sound. ive configured the tv to pass the sound control to and external device but still am not geting any sound passed to the soundbar. it works when i use bluetooth and pair them but I cant get it to work using ARC, any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, but three dots where? (I’m on an iPad)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks Roya brown 2 but you long winded reply to my solution will just confuse matters .
basically Samsung seem to refer to CEC as Anynet+
Sony have referred to it as Bravia sync on thier Bravia tv's so if you have a Samsung soundbar and are not getting sound if you connect the bravia to the bar using arc then its because you havent enabled anynet+ on your Samsung soundbar then make sure its turned on. when you then connect the HDMI cable to the Sony Bravia TV you will get prompted to say do you want to enable Bravia sync say yes to this. and you can then later go into the bravia sync settings and decide if you want the Tv to turn the bar on or off and if you want to be able to control the volume of the soundbar using the Tv's remote too. Ihope this helps because both Samsung and Sony were pretty clueless when I tried to get help from them to fix this
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @royabrown2,
I just noticed that the "menu-bar" is broken on the mobile site.
I will notify @Peter_S. about this issue, since he needs to look into this.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just a suggestion but instead of hijacking this thread can you start one about the menu bar being broken because that has nothing to do with this particular thread or issue ??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That’s OK, @romipat
I shan’t be troubling your thread any more, or indeed any thread you start.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
your call btw you wernt offering any suggestions or help, you hijacked a thread and started talking about a completely different and unrelated issue which is not good etiquette. I merely suggested thst you start a new thread about that issue. You've obviously taken some sort of offence to my courteous suggestion and I cant help or change that so that's fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
(I know I am breaking my promise by replying, but.....)
You asked a thing of me, and I went much further than you asked in promising never to darken your threads again. Which ought to make you happy, shouldn’t it?
And no I didn’t take offence at your courteous suggestion. But if you review the thread, you might find your earlier discourtesy to me, relating to an on-topic post of mine.
Though even there, I did not take offence; just noted, sadly, that further discussion with you was unlikely to be profitable for either of us 😞
Though, as ever, we must remember that the thread will likely by read by others, now and in the future; and I may hope that they find something of value in what I posted, even though you didn’t.
- « Previous
- 1
- 2
- Next »
