Optical Sound Output - Is this a bug?
Simply4Me
I've connected my Bravia 49X83's audio output to an external audio system using an optical cable.
The Speaker setting is set to Audio System.
Under Headphone/Audio Out there is a choice of Fixed or Variable.
I want to control the audio level with the TV's remote, so I select Variable.
But the optical audio output is constant - it doesn't change from the TV remote.
Surely this is wrong?
11 RÉPONSES 11
mex_dj
Hey man! thanks for starting this thread - it definitely helped me to find this solution (issue was exactly the bug you described) :
in Audio-Menu:
1.) set Speaker -> TV Speakers (this will enable the "Headphone-Speaker Connection" setting)
2.) set Headphone-Speaker Connection -> Off
3.) go back to Speaker and set it to Audio System
hope this helps :slight_smile:
Dollarfish
Nouveau
Any update on this?
I just got Sony XF90 and facing the same issue.
Actually I can control the volume level of the audio system when browsing the android options(click sounds), but when I start youtube or kodi the sound is fixed and cannot be controlled.
