This TV was bought in London and is now in Srilanka. It has worked for a bit more than a year in Srilanka. When trying to turn on TV now there is a red flashing light, which never happens, and also the TV screen doesn't turn on. If anyone has any idea please can you help me?? Thank you.
Hi @Anbay.Sivam and welcome to the Community
How many times is the red light flashing?
Can you try a power reset?
"The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. Try power resetting the TV and check if it resolves the issue. To power reset, turn off the TV and unplug the TV power cord from the electrical outlet. Let it remain without power for 60 seconds. After 60 seconds, plug the power cord back into the electrical outlet. If the TV is plugged into a power strip/surge protector, remove it from the power strip/surge protector and plug it directly into the wall outlet. Turn ON the TV and check if it works as expected"
Let us know if anything happens.
