TV keeps losing WiFi connection
DavrobinSony
Explorer
Android TV KDL 43W756G software up to date, no other WiFi networks nearby keeps losing WiFi connection when switched on (rarely when TV has connected & is working). Go to setup to reconnect: does not always connect. Sometimes turn WiFi off & back on again sometimes works, otherwise needs to reboot TV... At which point WiFi connects perfectly.
Tags (1)
2 REPLIES 2
EdwinaU
Moderator
Hi there,
Please try these tips for intermittent wi-fi connection issues and let us know how you get on.
Best wishes,
Ed
DavrobinSony
Explorer
Tried some tips - but no joy. It looks like I'm at the limit of WiFi (70-80dB signal) so have switched to a wired connection instead (using Ethernet over mains).  However, this too is proving to be somewhat unreliable.  I've switched  off WiFi so only on wired link.  I also need to check the error logs on my router.
