Hello,
I just bought the K65XR55B model which is Bravia 5, Android 12.
I understand that the Ethernet input is 10/100Mbps and reading a bit about this, I understand some people use a USB3-Ethernet adapter to work around this and get higher speeds.
A model that seems to be constantly mentioned is TP-link UE300 and TP-link UE330.
I was wondering, is there anyone here that also uses Bravia 5 (and/or Android 12) TV and can confirm the above models (or any other model, really) works with such a TV without any issues, and that it really improves speed?
Thank you.
I have a Bravia 7, but that should apply to you.
I also have a TP Link UE 300 adapter can confirm that everything works wells. I connected it to the USB 3 port and I'm seeing better speeds
