I have:
When setting spatial audio to be outputed to receiver, the sound keeps dropping.
When I select uncompressed audio formats, it seams ok
Given earc should pass through these audio formats, the sound drops every second.
Is this a bug with recent firmware earc update to this TV?
No update has solved this issue.
I tried various things recently.
I've tried:
- toggling earc off and setting the audio to dolby digital from xbox to pass through, better results than atmos, but still drops
- turning of pass through and getting tv to process audio which results into audio lag
The only thing that works is uncompressed audio set on xbox with 120hz set.
I can also confirm that my friends PS5 he borrowed me was giving similar results when set to digital audio and playing a game 120hz.
It's definitely the tv 😞 .
I believe Sony is already working on an update for the 2020 TVs, but might be delayed since the 2021 models have just started releasing.
Have either of you tried reaching out to the Sony support reps?
- JD
I have same issue
when set xbox series x to 4k 120hz and dolby atmos, sound drop frequently on earc a/v reciver(denon x2600h)
Same problem here, even the 2021 sony models have the same problem
Sony HDMI 2.1 eARC At 4K 120Hz, Does It Work? A80J A90J X90J X95J X900H - YouTube
Hey Javad.mf, have you tried the steps mentioned on the thread? Hi Gshinert, Sony usually holds an investigation when an issue comes up, did you ask to be updated? Let us know what they say..
I’m having same issue with Xbox series X but all is good with my PS5. Any updates on fixing this annoying issue? Thank you
That's pants!
They really need to sort this out.
I'll buy LG next time, they have had a better ride.
That's a well detailed video 👍
