- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Xperia C5 not charging when on
Hi guys,
Need your help here.. Anybody know what to do or have any solution to my problem?
My Sony xperia c5 cant charging when its on. but if i turn off the phone, its will charging the phone. Just happen tonight.
Any solution?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I discovered that the latest Play store at times hangs, cpu usage Spike and battery discharge very fast. Hopefully Google will release a bug fix, I already sent report and got a message saying that the issue is acknowledged and replicable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi F4yri5h,
Welcome to the community,
Have you tried different ways of charging the device, say using a PC instead of a wall charge and if you have did you get the same results?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hey i am having the same problem from 1 day ....my phone is getting charged when it is turned off but it is not charging while it is on...and also not in safe mode...plzz sony give me a solution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tried to connect the charge and even with pc.still npt charging when on? need a solution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi
I had the same problem when as you did today,
Try simplying swtiching the charger, for me that worked, hopes it works for you!
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I had face the same problem on my C5.
Being tried everything from reboot to put it back on factory setting.. At last I just switched the usb wire on my powerbank from 1.0A outlet to 2.1A outlet. DINGG!! The charging back to work..
Wish this work for u guys as well..
