Please help! New DSC-H400 memory slot problem
Hi there,
I literally just bought this product, but the company I bought from will do nothing to help me return it.  It arrived and seemed OK with my memory card, then when I ejected the card a piece of the memory card fell out.  I bought a new card and tried several others (all compatible with this model) and it keeps coming up with 'reinstate previous card'.  Obviously I can't as it's broken and won't work anywhere.  No card is working, the error comes up every time.  Each time I have only taken the card out whilst camera iis off.  Tried taking battery out etc, looked in the slot with a torch and there is nothing in there, all looks immaculate.
I urgently need a camera but have no idea what to do about this, no one at the store I got it from will help and I paid over the odds to get it on a finance deal so I'm really worried.
Many thanks, would be so grateful for advice!
jen
3 REPLIES 3
Nobody-in-particular
Contributor
Jen try the following taken from the help guide.
Digital Still Camera
DSC-H400
Initialize
Initializes settings to the default setting.
Even if you execute this function, images are retained.
MENU - (Settings) - (Main Settings) - [Initialize] - [OK] -
Note
Be sure not to remove the battery pack while initializing.
I am not sure if this will help with your problem but thought it worthy of mentioning.
Thanks, I can't find any initialise option in the menu settings at all.  I have, however, formatted the memory card whilst in the camera, I've also tried several other memory cards so I think the slot is faulty.
I bought it through Littlewoods who apparently don't accept returns, I've only had it since Dec 3rd so I'm getting very frustrated as it arrived in this condition but I don't seem to have any option to return it.
Thanks for your help, I think it's just faulty, I've tried all online fixes and nothing has worked sadly.
Contributor
If you believe that your camera is indeed faulty and the retailer is not forthcoming with a refund or replacement then you could try raising this with the finance company.
