I am looking for a micro system, less than £100 preferably, that is compatible with bluetooth headphones.
Apparently I need a system that can have bluetooth output not just input. But i cant find what i am looking for.
I actually bought a sony from Argos and their help said it was compatible but on speaking to sony it is not.
I am amazed that there seems so little use for headphones since you see them everywhere and there is so much greater choice than there used to be - but if you dont have a phone or tablet you dont seem to be able to use them.
Please someoen help me.
Hi there
Have a look at a range of products called "Bluetooth Transmitters" on Amazon. Something like this:
https://www.amazon.co.uk/Bluetooth-Transmitter-Receiver-TaoTronics-Simultaneously/dp/B016UF7J5C/
Could enable you to have a far greater choice in terms of which micro-system you get as it appears bluetooth is a priority for you.
Cheers
Thanks
so just to be clear you need a headphone port to plug in something of this kind?
The system we have bought doesn't have one. But we can take that back (we were advised it would be possible to use with bluetooth but it isnt) .
so just to be clear you need a headphone port to plug in something of this kind? it has an AUX IN port - would this work?
