Sony CMT-CP300 CD drawer problem
Hi I have a Sony CMT-CP300. The CD drawer will not open: when I ask any of the three CDs to eject, I can hear a noise as if it is trying to open the drawer, but no movement is visible.  I cannot find a reset: can you help, please?
1 REPLY 1
Anonymous
Not applicable
Hi there
I have had a look at the manual and the service manual and I cannot see a way to help you - I also cannot see a way to manually eject the CDs (without opening it all up).  The CDs have either jammed each other, or the mechanism has developed a hardware fault (most likely a rubber band that has snapped from the draw mechanism).
I would advise you contacting an authorised Sony repair centre to get this fixed.  See:
http://services.sony.co.uk/support/en/repair/asc
I am also attaching the Service Manual for this unit too - it may help you.  See the PDF attached below.
Cheers
