Hi there
Normally you would connect all devices via HDMI to the AV Receiver, and the AV Receiver to the TV via HDMI.
I am unsure on how you have connected things up so its hard to say where your issue lies. However, my advice is to go through the HDMI Troubleshooting guide: HERE - especially the advanced part as this explains plugging each device in individually.
Also, i have to question why you need the Sky box, Freesat box and YouView box all connected to the same TV. The Sky box would probably be sufficient, without the other two?
Cheers
Hi there
If your using HDMI -ARC connection, removing to optical cable - this is not needed and only confuses the devices
Let me know how you get on anyhow.
Cheers
