HT-ST5000 Sound bar with sound field stuck on 3D surround
audioone
Explorer
I have a HT-ST5000 sound bar where I cannot change the sound field from 3D surround, have tried a hard reset with no joy all other functions are working ok has anybody got any suggestions.
5 REPLIES 5
Piscie
Hey @audioone,
Have you tried pressing on The Sound Field button repeatedly to change the sound mode? and have you tested it with any different device to see if there's any difference?
audioone
Explorer
Hi Piscie New
yes l have tried repeatedly pressing the field button with no luck, no matter what sources are being played through the sound-bar I cannot adjust the sound field from 3D.surround.
 I am now waiting for Sony support to get back to me.
thanks for your suggestions.
SkyNet404
Specialist
Hey there,
Hopefully they can get back to you with a fix for this.
But you can check the manual as well, page 30: https://bit.ly/3DdBJOp.
Hope it helps.
U2MrIzz
Explorer
Hi audioone
I was wondering how you got on with your HT-ST 5000 sound bar being stuck on 3D surround because the same thing has happened to me recently??
SkyNet404
Specialist
Hey @U2MrIzz
I would suggest trying the above first and test it once more.
Hopefully this helps.
