hello can't anyone advise? when connecting a set top box from Vodafone to htzf9, there is only sound but no image. just writes see the picture.
You have to connect the Vodfone box directly to an input of your TV and then use ARC HDMI connector to send the sound back to the soundbar.
Cheers
Peter
yes problem solved. my tv doesn't have hdcp 2.2 so i solved the problem with the help of the converter from hdcp 2.2 to hdcp 1.4.
@Swindour I assume that's a device/adapter that you bought, if so, could you share the link for it here and mark your post as the solution so others can benefit as well?
@Swindour Thanks a lot for sharing this! It's extremely helpful for others who may come across the same issue in the future.
I'm glad I helped.
