I want to use the TV surface speaker as center speaker mode in my home theater configuration,
I only have audio decoder without amplifier, but I cannot find anything in the manual regarding the recommended amplifier power or the speaker impedance.
I found this
1- Does this mean that the TV will convert the input to suitable line and use internal amplifier to drive the surfac Speaker?
2- if so, does it mean I can simply connect line level audio without any amplification to this input and it will still work as normal?
1 TV will ask just as a passive speaker. It's designed to work with AV receiver so no worries
2 no it won't work
Hi there,
If you get in touch with the Sony Mobile support team here they will be best placed to advise you further.
Best wishes,
Sean
