Android TV USB HDD Recording
35,609  Views
Live recording
2K models: Allowing you to record live broadcasting, while still enjoying content from other inputs such as Blu-ray Discs, online streaming services and Internet browsing.
4K models (equipped with Twin Tuner): Allowing you to record one channel while watching another or still enjoy content from other inputs such as Blu-ray Discs, online streaming services and Internet browsing.
Full Timer Recording
2K models: Allowing you to schedule recordings.
4K models (equipped with Twin Tuner) Allowing you to watch and schedule multiple channels simultaneously.
Event Duration Extension
Extend the time before and after the recording time of your selected programme. For example, extending the start time by 5 minutes and end time by 10 minutes for a programme between 16:00-17:00 shown on the electronic programme guide (EPG), will record from 15:55-17:10 - displayed on the Timer List.
Event Duration Extension - start and end time
Event Duration Extension - disable, 5 min or 10 min
IMPORTANT:
If two sequential programmes are set to record, and the Event Duration Extension causes an overlap, the earlier programme will have priority. For example: if the user sets the timer for a programme at 16:00-17:00 and another at 17:00-18:00, using the same timings, the first programme will be recorded between 15:55-17:10 and the second programme between 17:10-18:10.
Deleting programmes from the Timer List
The ability to delete Timer Recorded programmes from your TV. Use the following steps:
  1. Select Timer List
  2. Press the Action Menu button on the remote control
  3. Select Delete from the menu
  4. Check the timer/programme to be deleted and select Delete option
Timer List
Delete recorded programme
NOTES:
  • Programmes can be scheduled to record from the electronic programming guide (EPG)
  • The "Event Duration Extension" features extends the recording time (start/finish time) to avoid missing the recorded programme (full timer only)
  • In order to cancel the timer recording, you will need to navigate to the "Timer List"
15 Comments
