Solved! Go to Solution.
I have the problem when phone is connection to a PC through USB.
Only with USB connection?
Not when plugged to wall socket with sony charger?
Firmware version of your xperia L?
i am using Xperia L since 11.10.13 and i have same problem when charging, it seems problem is in sony charger cuz lots of people having this problem. though i didnt try with other charger yet.
Never expected this from SONY brand.
I have same problem when i charging With PC's USB.
I have the same problem.
Really seems a hardware problem since it happen when the charger is plugged in.
I tryied with another sony charger (700ma instead of the 800ma of the xperia L) it does less, but still shaking.
sounds a very similar problem with the Xperia mini pro (cicada effect). the power supply was making interference with secondary microphone. (I had that problem too).
I am updating the firmware since i have the phone since 2 hours only! but i really doubt i can solve this issue.
thanks god I can return the phone since is from Amazon.
Sony
1:- Change usb cable and te charger blade .( This work for me)
2:- If u saw a notification about device update software then do ur update.
3:- Try to charge ur phone in low power sources like laptop, ups, power bank etc.
4:- If te tips mentioned above doesn't work. Charge ur phone without using !
Hope it will help!
