- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
audio jack stopped working
For some unknown reason my audio output jack has stopped working on my new VPCSE. When I plug in my earphones the laptop speakers continue to play and nothing can be heard on my earphones. If anyone out there can help, I would much appreciate it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi baccoboy and welcome.
It could be a recent update or a hardware or a software problem but try the following to see if anything helps.
Go to Control Panel -> Hardware and Sound -> Sound
You should see your Audio Devices: - Speakers, Digital Audio, and Headphones
Plug in your headphones and select Headphones
Select 'Set as Default'.
It should then automatically switch between Speakers and Headphones.
However, it could also be a hardware issue. If the above doesn't work try connecting and disconnecting the headphones a few times just in case it is a poor contact.
