Does the in-built card reader on the VGN-NR38E read SDHC cards?
IzzyS
Visitor
The title says it all - is there anyone here with a VGN-NR38E laptop thats used an SDHC card with the in-built card reader on the front because im curious to find out whether the SD card reader will also read SDHC cards or not. I searched on Google and it seems that some SD card readers can read SDHC cards and others can't, it depends on whether it was built with the new format in mind or not(?).
Anyway if anyone knows then please reply,
Thanks alot :slight_smile:
edit:- or if anyone knows if there's a webpage somewhere or something that lists the full spec if it might indicate whether the SD card reader is SDHC compatible then that'd be great, thanks.
0 REPLIES 0
