Part No. VGP-BC10 - Extended battery charging adapter
SOLVED
profile.country.en_GB.title
MonsterEnergy_IT
Visitor
Please can someone advise if the following VAIO extended battery charging adapter (part no. VGP-BC10) is available to purchase separately?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi MonsterEnergy and welcome.
I can't find one in the UK but they appear to be available in France and USA.
http://www.mgmi.fr/SONY/VGP-BC10_4989.htm
http://www.sparepartswarehouse.com/Sony,Laptop,Part,148966111.aspx
I suppose as it comes as a free accessory with the battery, that means there is very little demand at present.
:thinking:
3 REPLIES 3
Blencogo
:thinking:
amcamillo
Visitor
Hi everyone,
I bought a vaio and it came along with this acessory, but I have no idea how to use it... Do I need anything else? I guess I am missing a battery sheet, I mean, I should be able to use the VGP-BC10 along with an external battery, correct?
Thanks in advance.
rich912
Contributor
Hi amcamillo,
As you have gathered the VGP-BC10 is an adaptor for use with the optional sheet battery to charge when not attached to the notebook. I have no idea why this was delivered with your Vaio and assume that you didn't order the optional sheet battery?
Which Vaio model do you own?
Rich
Go n-éirí an bóthar leat
