Hi, im having a problem with my computer. It works fine but when i connect to Internet nothing responds, not even th Ctrl+Alt+Delete command. I have asked a few people and they think the problem is with the hard drive.
So I wonder how I do a computer backup, how I change the hard drive, what hard drive I need to a Vaio model: vgn-fw41e/h and how I re-install my computer?
Thank you for your help!
Hi erikoman,
Before going down the route of replacing the hard drive I suggest that you first rule out other possible causes.
First run a check on the hard drive for errors.
http://windows.microsoft.com/en-GB/windows-vista/Check-your-hard-disk-for-errors
If after that you still have the same issue then try booting in Safe mode with networking (F8 at boot) – check whether the problem still occurs.
If possible download a different browser (eg Firefox) on another computer and install that on your machine – does the problem still occur?
Rich
As an additional step, check error logs at Control Panel - Administrative tools - Event Viewer.
And when was the last time this device worked well?
I walked in wondering the same thing, but i just want a bigger internal HD.
Same model. vgn fw41eh, is it sata or ide and of so what version? 300? 600? 150?
Thanks.
