So many problems with my VPCEB2Z0E
profile.country.en_GB.title
NY_Ranger_Oli
Visitor
well first off i am peeved to say the least with the battery which has refused to charge above 80% since buying it 18 months ago, as i didn't use it very often at the time it wasn't a major concern on it's own, however since then i am now having problems with the bluetooth which doesn't register as being compatible with Windows 7, and finally the final straw, my Blu ray player will not play or even register my blu rays, dvd and data content it will, but the drive makes a racket for a while and then.....NOTHING. Over £700 for this laptop and if this wasn't bought for me by my deceased grandmother i would throw it away
Please help me someone
1 REPLY 1
profile.country.en_IE.title
DeletedUser
Visitor
The battery part is easy, it's a safety feature put in by Sony to help reduce battery degradation.
To turn it off:
- Start
- Type in "Vaio Control Centre"
- Open it up
- On the left sidebar click on Power management --> Battery
- Untick "Enable battery care function"
You can change settings in "Advanced settings" if you choose to use this feature.
I may be able to help with the Bluetooth issue, not sure about the Blu Ray though since I've never used one. Off the top of my head, update driver / make sure the Blu Ray is from the correct region?
Can you provide more information about the Bluetooth issue? What happens when you type in "Bluetooth" into Start?
