Audio flicker/chopping over bluetooth A2DP
profile.country.sv_SE.title
aksel.g
Visitor
When I use a bluetooth stereo headset with A2DP together with the Sony Tablet S 16 gb WIFI the audio is very choppy and it changes pitch. But, if I disable the wifi the problem disappears and it works as it should. Someone else who is experiencing this problem? And maybe have a fix?
Maybe it has something to do with the wifi problem with bad signal/disconnecting that is(or maybe was) another problem with the tab.
The thing is that I use the tab with spotify, and spotify is pretty useless if I disable wifi. Of course I can use offline playlist, but that's not an option.
0 REPLIES 0
