Is it possible to print from s tablet?
SOLVED
profile.country.en_GB.title
stillin40
Visitor
Just acquire a s tablet. Can I print to an ePrinter?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.nl_NL.title
breedBenR
Member
In the market, Apps are available that allow to print certain types of files to certain types of printers in your home network, via Wifi.
If you have such a printer, search for its brandname in the Market.
4 REPLIES 4
breedBenR
Member
mpattenden
New
I have an Epsom wifi printer and the epsom iprint android app - it works perfectly.
So as suggested just do a search for your printer manufacturer and see if the have an app.
hth
Padster
stillin40
Visitor
Thanks all. I have downloaded the HP app and installed it. The printer is recognised when I actually run it, but when I try to print it says print size not recognised/set. Am using HP photosmart ePrinter that works perfectly with iPad - Suggestions please and thanks in advance
Watashiwateshdes
Contributor
For support on the app, you wioll need to contact the developers or the manufacturer as the Tablet has no bearing on print sizes etc
