Power supply usa? Do I need a converter to use my tablet in the USA?
SOLVED
profile.country.en_GB.title
bugsy65
Visitor
I have a Sony tablet which I want to take to the USA where the power supply is 110 volts Do I need a converter as UK is 240 volts ?
Message was edited by: bugsy65
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.nl_NL.title
breedBenR
Member
you can use your original adapter. it says 100-240 Volt accepted on the sticker on its back.
you may need a travel adaptor plug. Any electronics shop or airport gadget shop is able to provide you the right connector / replacement cord for the part between wall socket and adaptor.
2 REPLIES 2
breedBenR
Member
bugsy65
Visitor
Thanks  very much .
