Hi All,
I bought a Tablet P series and did the intial setup and everything was fine, unitl I update the System update. After the update my unit is able to identify the netowrk and it connects and dissconects in the same second...this just goes on in a loop...I did removed the network from the wireless list and then re-configured the netowrk..but the issue still stays the same. Did re-configure my router but still not use. Even did a reset on the unit but still no use.....
Can anyone help me out to get this sorted,,,,,,,,
George
I've seen another user report something similar. It appears to happen when in the same session you connect to the router for the first time, and start an update a bit later, without having disconnected/rebooted before.
For the other user, performing a factory reset after the update cleared the problem (this will mean downloading and reinstalling your apps and setting up all your accounts and widgets again).
