Video Unlimited problems
SOLVED
profile.country.en_GB.title
Hostthedog
Visitor
Hi all.
Having problems with this recently.  When I run the app it tells me that I must download an update.  I do this, am told in the notification bar that it has downloaded, try to run it again, and the message comes up again.  Loop until disheartened :smileyangry:.
Any ideas how to fix this please?
1 ACCEPTED SOLUTION
Accepted Solutions
sehuxle
Member
If I remember correctly, you need to tap the notification bar (does it show as a tick). That will bring up a small box telling you it's downloaded, then I think you tap again in the box and it will install it.
At least thats what I remember doing....
2 REPLIES 2
sehuxle
Member
Hostthedog
Visitor
Many thanks, so simple and yet not at all obvious!
Simon :slight_smile:
