Android 9 problems with Bluetooth
SOLVED
Olivatto
Visitor
After the update to Android 9 i have been problems with Bluetooth devices. Some aren't found, others found but with no success with pairing. I can't use my Bluetooth, please fix that!!
1 ACCEPTED SOLUTION
Accepted Solutions
fucosk
Visitor
I have a different phone (pixel 2) with the similar issues. Still very unreliable android 9 BT implementation. What works for me is to change bluetooth AVRCP protocol version In developers settings and restart the phone. No matter the version, in seems like the change sitelf clears some garbage. Then everything connects for a while. But you have to change it occassionaly to fix it. Total shame on google developers to produce such.
31 REPLIES 31
profile.country.NL.title
Strampke
Try this
Goto settings → apps & notifications → tap app info → tap 3 dots upper right corner → tap show system → scroll to Bluetooth → tap Bluetooth → tap Storage → Tap Clear Cache & Clear data
Restart device and report back if it helped you solve your problem.
Olivatto
Visitor
Hello strampke, i followed the steps and It not work. I really think that the problem is the Android Pie, until the devices that were paired before the update are not working.
Do you have another suggestion??
Thank you in advanced.
sMajmac
Visitor
I do not think that the problem is with Android Pie. I updated successfully when it was released and I have had no problems with Bluetooth ... or any other things on my phone. It is running smoothly and there have been no problems.
ZechG
Visitor
I'm have Bluetooth connectivity problems after last update as well.
OzzyCLF
Visitor
Same problem over here...  Bluetooth is useless...  Can't connect to BT devices. None of them.  Can't connect via nfc neither..
So bad sony!
I need a solution soon!
Zappa36
Visitor
Same problem here . Any solution?
Olivatto
Visitor
Nothing yet.
RooiValk_ZA
Visitor
Me as well, after 9.0 i cant play music through my onkyo receiver which was never an issue before. It pairs, picks up the phone, XZ Premium , but no sound coming through receiver. Did not have any issues before pie update.... Please sony advise.
Profyler1
Contributor
There was several bluetooth options in developer menu. DId you guys check it out?
