I bought my Xperia XZ1 Compact nearly five months ago, in early April. It worked fine for several months with minimal battery drain, but the drain has gotten absolutely atrocious after July's update.
I'm not even joking with this. I have done absolutely no changes to any of my settings or apps - I've had the same apps on the phone since April (including downloaded ones). The battery drain was very good for the first three months or so - 100% battery drained in around 1 and a half days.
The past few weeks, however, the drain got progressively worse (24 hours from 100% one day, 13 hours from 100% the next). It got so bad that I did a complete factory reset, and the phone was amazing when I started it up again - the drain showed 7 days, 1 hour from 100%. I let the phone perform the system update and pre-installed app updates while it was charging... after unplugging the phone when those updates were installed? Battery drain showed 12 HOURS from 100%.
It literally just showed that after a factory reset and required updates, without any app usage at all, immediately after unplugging the charger. Right now it's been 1 hour since the factory reset, and this is what it looks like:
The language is Finnish, and the screens read:
Battery level and estimated time: 90%, 11 hours and 50 minutes remaining
Usage after last charge: Phone idle, 2%, 1 hour 3 minutes; Screen, 2%, 53 minutes
Device usage: last full charge, 1 hour 5 minutes ago; screen usage after full charge, 53 minutes
This is with screen brightness dragged all the way to the left (0% brightness). The drain occurs on both Wi-Fi and mobile data. Enabling Safe Mode doesn't help (which means extra apps do not cause it).
Is the battery on this phone supposed to do this after four months, or did the system update screw everything up that badly?
Also, why exactly does my screen show 53 minutes of use when my phone is very clearly idle, with the screen black? I'm still certain an update did this, considering I have done absolutely nothing to my settings since the reset. Which is why, as a customer, I'm expecting a future system update to fix this battery drain issue. If it doesn't happen, I'm going to have to change my phone after four months. I'd wanted an Xperia Compact instead of the bigger phones since my hands are small, and I am NOT going to be happy if this problem forces me to switch to a bigger one that will be difficult to hold. Sony, please just do something about it and actually check your updates. An idle phone literally after a factory reset is NOT supposed to do that, and it is in no way my fault. This is why it is also not my job to fix it through workarounds. As the company making these phones, it's yours.
Honestly, I am so angry right now that I'm driving my family crazy by swearing and chewing up the scenery.
I too am experiencing the same. This is very annoying. Is Sony ignoring the problem altogether? It seems to me from the number of people on this thread that it's quite wide-spread!
Since I installed another launcher (Nova Launcher in my case) instead of Xperia Home, I do not experience any battery drain anymore. I vividly advise anyone with a battery drain problem to try another launcher. BTW, Nova Launcher is muuuuch better than the default one…
Hi to all
I've got the same problem with my XZ1 device. When it was new, i was able to use the phone for 2 days with 1 full charge. Now it lasts only 1 day.
But I tested several things (disable apps in backgroung, switch off everything etc.) and I've figured it out, what causes the battery drain on my device. When I switch off 4G network (the mobile data still can be active, just use 3G instead of 4G). On the first pic 4G was active the whole time (the mobile data doesn't have an affect), on the second pic I used 3G and you can see when I turned off the mbile data too.
Yes, I know, stamina is active on the second pic, but trust me, that has only a very little affect on the battery drain.
Try it!
