i have xz premium .. whenever i connect it to my pc it starts charging rather than showing a pop-up to select the action ... i have tried everything from using 3 different cables, 3 different PCs, resetting, downloading xperia companion and whatever not ... my other phones (oneplus 6 and s9 plus) work fine only this has problem .. i even downloaded and installed drivers from sony website but no luck .. Kindly Help me .. i have also tried clearing the ports .. in settings menu the usb selections are disabled but in the developer options they are set to data transfer, also the debugging is enabled ... G8141 on android 9.0
