Hi, my Xperia has problems with charging. It starts charging, but after about a minute it stops. I did try every possible settings for the batery. So l usualy try to plug it off and on again, but the same occurs. So I am unable to charge this phone to max. ever! when I go to work in the morning it is on about 12-30% ONLY so it shuts down at about midday and I can not use it till I return home.
Have you tried a different charger?
Only asking because that is usually what causes this type of behaviour
