Imaging Edge Mobile 7.3.1 does not work
SOLVED
profile.country.NO.title
ThorEgil
Member
Hi.
My experience with the new version 7.3.1 of Imaging Edge Mobile with my A9II - OnePlus 7 Pro / Android 10
- Connection via NFC does not work.
- Connecting via WiFi is very slow, when it works at all.
- I have to scan the qr code every time I want to connect. The app keeps forgetting the camera connection.
- And the Save Settings function just hangs until the app crashes.
1 ACCEPTED SOLUTION
Accepted Solutions
ThorEgil
Member
This is a very old thread. The current version - 7.6.0 - works just fine, at least on Android.
14 REPLIES 14
Pascale_F
Moderator
Hi ThorEgil
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi ThorEgil,
Have you tried forgetting the WiFi network generated by the camera from the saved networks on your phone ?
Cheers,
The_Black_Rose
ThorEgil
Member
Yes.
Cleared everything, reinstalled the app.
The only thing that helps is rolling back to previous version.
The_Black_Rose
Specialist
Hi ThorEgil ,
Unfortunately, rolling back isn't possible.
My phone is running Android 9 pie and I am not facing any issue while connecting the camera to my phone.
I'd recommend testing another phone.
Cheers,
The_Black_Rose
ThorEgil
Member
Rolling back is as easy as uninstalling the latest version and replacing it with the previous version downloaded from one of the many apk archives around.
I have the phone I have - one of the best yet produced, and according to the feedback to the app in the Play store I'm not alone with problems. The latest version is a total failure.
The_Black_Rose
Specialist
Hi ThorEgil,
Installing APK files is not always guaranteed to work and to be honest, Sony will never recommend this or guarantee its functionality.
Cheers,
The_Black_Rose
ThorEgil
Member
The apk is the previous version of the app. Nothing more, nothing less.
The obvious solution to the problem is that Sony fixes the showstopper bugs in the app ASAP. They did a very sloppy job in the testing department before releasing version 7.3
SnapperDD
Explorer
This app is not working on my android phone, how do I revert to the previous version please?
dnjonjo
New
Experiencing same problem. Too
