Hi…..since the last big update my tv does not switch on immediately.Every so often it goes into reboot mode and I get the “Sony” symbol followed by the “bouncing balls”and finally the Android symbol.This does not happen every time and it is only happening since the new update.Is this a common problem and does anybody know if Sony are going to address the problem.
Thank you
Den
Solved! Go to Solution.
What TV model do you have and have you tried double-checking that you have the latest software? This used to be an issue with some older TVs/software versions but was fixed.
