I have recently purchased the above product after previously using the DSC W270 & DSC HX50. They were both excellant when recording pop concert footage both indoor & outdoor. Recently I recorded both an indoor & outdoor gig and the problem I have with the HX90 is that the audio is both tinny & distorted which I never had with the first two cameras. I have recorded using the AVCHD and 50i 24M (FX) settings.
Do you think it is a "settings" issue or could it be a fault with the camera?
Thank you very much
Solved! Go to Solution.
I do not have a HX90 to compare to, but just like you, I would expect the sound to be the same or better. Maybe you can record a movie sample from a different HX90 in store and compare?
Is the sound normal if you for instance speak to someone while holding the camera?
Portmixus, thank you very much for your reply. I may try this at the next gig I attend
