how to use mobile data on computer with the help of USB cord .
for model no xperia mdual c2004
Hi swt,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Make sure you also have the appropriate Internet settings before performing a Tether to the PC.
Menu > Settings > More > Internet Settings > Accept Disclaimer > Select Network.
Once done follow the instructions in the link above.
Hi swt,
dear ,
in my phone there is no Accept Disclaimer
plz. help for setting for how to use mobile data on pc
Do this
1) Connect your phone to Computer via USB
2) Go to Settings>More>Tethering & portable hotspot
3) Check USB Tethering
4) Computer will install drivers and ask you set a new network
5) Choose any one of them (Preferably home network)
6) Computer will automatically configure the settings and you can start browsing.
Done
dear friend.
my phone c2004 m dual .having charging probleme .
i submit the phone to sony service centre . dt 20.3.15. aurangabad maharashtra.
but probleme is same & under checking.
already i cahnge the cahrger & usb cable sony make.
solution about this
mobile is return as it is without repairing from authorised service centre .
charging probleme .
can c2004 xperia able to charge with wireless charger .
if yes , which charger.?
phone battery is ok .
problem in phone pin where the charge pin attached.
if we adjust the pin mobile is charge .
charger & usb cable also new sony make.
pl. suggetions
What is the problem exactly?
Is the charging slow or no charging at all?
dear sir,
it's charge but need to adjust the pin wher we joint at mobile end.then it charge.
charger & usb cord also new sony make
Most of the smartphones today use the same kind of charger so use any other one.
If your phone charges correctly, then the problem is with your charger.
Otherwise it is a problem with the handset.
The service centre will probably change the USB point in your phone.
