Sullyman
Explorer
Best way to connect
Hi everyone, very non technical 40 something here and would like to know the best way to connect a Bravia 46w905abu to a ct660 soundbar. I'm currently using an optical lead. Many thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
The best way (in my oppinon) is to connect the HT-CT660 to the TV via a HDMI cable - removing the optical completely.  This should also give a mainly single remote control solution.
What you need:
1 x HDMI 1.4a cable (note: it must be a 1.4a version)
How to connect it:
  1. Disconnect and remote the optical cable between the two
  2. Connect the HDMI 1.4a cable to the TV's HDMI 1 (ARC) port and to the CT660 HDMI TV OUT (ARC)
  3. Enable Bravia Sync on the TV and CT660
Hope this helps
2 REPLIES 2
Anonymous
Not applicable
Hi there
What you need:
How to connect it:
Hope this helps
Sullyman
Explorer
Will give it a go. Many thanks
