Am I the only one on the planet that has commentated about the real issue with the touchpad of the sony vaio ultrabook t series.
The problem is so obvious I am ultimatelly supprised it passed quality tests, infact I am almost sure that they either did not perform tests or the test person is utterly incompitent. This is not the result I would expect from sony of all companies, infact this is the reason I invested in a sony for quality and reliability.
The issue is with the double-tapping (essentially the Click+Hold), say I wish to move an icon or load an app there are occasions where the laptop does not register the initial tap, give it a double tapping or a single click it appears the touchpad's fault is it does not register some taps.
I have tested this issue at my local PC store where I bought this laptop on the same laptops and the issue is on them too, meaning this is a factory fault with at least all T-series ultrabook models.
This has to be addressed, fixed and a recall considered under warranty. Again, I am utterly dissapointed this issue passed the quality control and 'testers', I mean how did this pass them!?
