The "problem" should be related to bravia sync. If it is enabled you have to push the "sync menu" button on the TV remote and select to use the tv remote to control the tv and NOT the device. By default it send the command from the TV remote to the device and not to the TV once the connection is switched
You can disable this feature in the setting of the TV it is annoying for you.
