Who Me Too'd this topic
profile.country.en_GB.title
soundman13
New
SVE1712C5E Graphics Driver Issue
I've had my SVE1712C5E for a few months now - its now finally setup pretty much as i want it.
However I have noticed what could be an underlying issue with graphics drivers.
I have a 2GB Radeon HD card alongside the intel 4000. When I right click on the desktop now I only see the Catalyst Control Center. I'm sure I used to see an option for the 4000 & another option to select the default card to be used for different apps.
I have several graphics apps & games (steam & non steam) installed - it seems as though something may have overwritten or confused the original drivers.
I have tried reinstalling what I assume to be the original drivers from the Sony support site, but this hasn't fixed the issue.
I also get an error on ccc.exe quite regularly when I shut down (which I assume is the Catalyst Control Center).
Could someone firstly confirm exactly which drivers I should need to reinstall to fix this - or if there is anything else that I might need to do/check to get this running as normal again.
Thanks
Tom
